| 4.2L | 5.3L | Years | Details | |
.: Torque Specs :. |
| Lug Nuts | X | X | 02-09 | 105 lbs/ft |
| Brake Caliper Front Bolts | X | X | 02-09 | |
| CV Axle Nut | X | X | 02-09 | 103 lbs/ft |
| Wheel Hub and Bearing Mounting Bolts | X | X | 02-09 | 77 lbs/ft |
| Outer Tie Rod | X | X | 02-09 | 33 lbs/ft |
| Inner Tie Rod | X | X | 02-09 | |
| Upper Control Arm Mounting Bolts | X | X | 02-09 | 111 lbs/ft |
| Upper Ball Joint Pinch Bolt | X | X | 02-09 | 30 lbs/ft |
| Lower Control Arm Front Bolts | X | X | 02-09 | 192 lbs/ft |
| Lower Control Arm Rear Bolts | X | X | 02-09 | 177 lbs/ft |
.: Fluids :. |
| Engine Oil | 7 qt | 6 qt | 02-09 | 5W/30 Fully Synthetic |
| Engine Coolant | 10.8 qt | 12.2 qt | 02-09 | 50/50 mixture of clean, drinkable water and use only DEX-COOL® Coolant. |
| Transmission Fluid | 5 qt | 5 qt | 02-09 | DEXRON®-III Automatic Transmission Fluid |
| Transfer Case Oil | 2 qt | 2 qt | 02-09 | GM Autotrak II (blue stuff only!) |
| Front Differential | 1.7 pt | 1.7 pt | 02-09 | SAE 75W/90 Fully Synthetic |
| Rear Differential | 3.6 pt | 4.3 pt | 02-09 | SAE 75W/90 Fully Synthetic |
.: RPO Codes/Options :. |
| Axle Gearing | X | X | 02-09 | GU6 = 3.42 GT4 = 3.73 GT5 = 4.10 |
| Rear Locker | X | X | 02-09 | G80, means you have the OEM locker |
| 150 Amp Alternator | X | X | 02-09 | KG4, means you have this stock |
